6266 gen2 slow spool
Old Oct 13, 2018 | 01:54 PM
lagunabs2k's Avatar
Default 6266 gen2 slow spool
I have this issue where its hitting full boost at 7k, i did find a leak on compressor cover precision said it was normal to leak from that area when psi applied.
stock f20
6266 gen2 t3 .82
trackforged manifold
trackforged boost activated cutout
tial 44 with 7psi spring
mac 3 port
Old Oct 13, 2018 | 01:55 PM
lagunabs2k's Avatar
Old Oct 14, 2018 | 07:03 AM
umair's Avatar
That doesn't look normal to me if its leaking from there. Check to see if the gasket is in tact on the inside of the cover. You definitely have a boost leak or leaks.
Old Oct 14, 2018 | 07:18 AM
spectacle's Avatar
Looks like it's leaking way more than air. What is that?
Old Oct 14, 2018 | 07:29 AM
lagunabs2k's Avatar
I did removed it and seal looked fine
Old Oct 14, 2018 | 07:31 AM
lagunabs2k's Avatar
i was spraying soapy water, couldnt hear any hissing so i spraied on the comp cover and thats when i found that leak
Old Oct 14, 2018 | 07:40 AM
spectacle's Avatar
Ah makes sense. A small leak from the compressor cover area where the bolts attach to the housing is normal.
Post a datalog of a pull. We might be help to help diagnose the problem better that way.
Old Oct 14, 2018 | 08:30 AM
lagunabs2k's Avatar
Dont know how to post a log lol
Old Oct 14, 2018 | 04:06 PM
umair's Avatar
reach out to ap1cheif. He will help you out.
Old Oct 14, 2018 | 04:20 PM
AP1Chief's Avatar
Txt me 7173986782
stantaur
Feb 14, 2013 08:53 AM
rikhemi
Feb 23, 2012 09:42 PM
Sideways
Jan 1, 2012 12:22 PM
dibi
Sep 30, 2009 06:57 AM
blackey
Aug 6, 2007 01:02 PM
