70mm -vs- 80mm
Old May 9, 2009 | 04:43 PM
  #21
Sarek's Avatar
Originally Posted by ZSAK,May 9 2009, 05:30 AM
how does the e cut out actually work and is it prone to failure.
it's a y pipe connected to the exhaust. (i imagine connected at the downpipe) that has a flange with an electronically controlled "butterfly". You can connect it to a flip switch or even the AEM/EMS. My only gripe with the electric ones that it takes a while to open if you wanted to hook it up to open at certain rpms/boost via AEM EMS.
Another option for a cutout that I've seen recently available is a boost activated cutout that opens very fast. It uses a wastegate type of actuator that's boost activated. A "Supra" performance shop "Sound Performance" started manufacturing these this year. I'm thinking about getting one if my new exhaust is too restrictive (which I doubt). check it out:
Old May 9, 2009 | 04:49 PM
  #22
Sarek's Avatar
SP cut out in action:
http://www.youtube.com/watch?v=C556EHYUijA
cutout thread from supraforums.com
Old May 10, 2009 | 11:25 PM
  #23
Asura's Avatar
Ideally, take your car to the tuner and have the switch also toggle the nitrous map function in the EMS. Since the cut-out makes changes in the air-flow characteristics, you would want to atleast optimize both fuel and ignition tables to compensate.
Essentially you will be running open header and the AFR curve should lean out as a result.
-asura
Old May 11, 2009 | 09:16 AM
  #24
TRBOKEV's Avatar
That supra cutout looks really cool. I could go back to stock exhaust and be loud as hell when I wanted with more powa!
macdaddies911
Apr 3, 2010 06:37 AM
momofoolio
Oct 10, 2008 06:14 PM
