9krevvin's Build
Does anyone know if the IAC can just be removed?? I am going to be bypassing the coolant going through the throttle body, and was wondering if I should bypass this and put a block plate over it?
This may be a dumb question, but If you remove the coolant line won't the IAC valve be useless anyways? I could be wrong, If I am can you explain why it is needed? Thanks in advance for your help!
hopefully it flows better than this one:
http://cgi.ebay.com/ebaymotors/Sidew...#ht_500wt_1182
330 whp @ 11 lbs with a gt35
