Accessory Power
Old Aug 21, 2011 | 08:44 PM
  #21
Ken_SNISEN's Avatar
Can someone help me with which wire on the ignition harness won't drop voltage while cranking? I've been searching for an answer for a few days without luck.
Old Aug 22, 2011 | 07:13 AM
  #22
siadam's Avatar
I am trying to remember from memory, but if you look under the dash, there is a run of black loom that goes to the ignition (key) and it has a couple wires in it. I think the one with constant power was white with a stripe, I forget though, just test those, and you'll find what you are looking for.
Old Aug 23, 2011 | 12:37 AM
  #23
Ken_SNISEN's Avatar
So far I've tested the white/red and two black/yellow's, and all three drop voltages to the high 9's to low 10's.
I'm not sure how low the voltage is allowed to drop but it's not really a consistent 12 volts during cranking.
Old Aug 23, 2011 | 10:21 AM
  #24
siadam's Avatar
Thats normal, your alternator isn't running yet, and the battery is getting drained from the starter/coils/sensors/ecu/etc and everything else trying to fire up.
Old Aug 24, 2011 | 11:20 AM
  #25
Ken_SNISEN's Avatar
Ok. I'll give up on stabilizing the voltage after I upgrade the ground wire and try on a bigger battery that has more cranking amps.
kasher_khan
Jan 22, 2018 05:05 PM
mikefifth
Jan 22, 2015 01:32 PM
Corey Maurer
Feb 12, 2013 08:12 AM
Blurter
May 23, 2005 01:38 AM
fireball
May 8, 2004 06:48 PM
