Accompanying mods with SC/AC
I've been reading up but have not found a thread that states EVERYTHING needed to run a Comptech SC/AC smoothly.
I've found bits and pieces here and there but I'd feel a lot safer getting it all from one thread. And I haven't found anything on necessary differential mods (is it necessary?). I just wouldn't want to take info from a whole bunch of different threads that are really addressed only to specific users.
So I guess my official question is: What would I need to run a Comptech SC/AC as smoothly and reliably as possible while still maximizing power gains? This includes drivetrain, breathing, electronic, and other engine mods.
Thanks for your help!
I've found bits and pieces here and there but I'd feel a lot safer getting it all from one thread. And I haven't found anything on necessary differential mods (is it necessary?). I just wouldn't want to take info from a whole bunch of different threads that are really addressed only to specific users. So I guess my official question is: What would I need to run a Comptech SC/AC as smoothly and reliably as possible while still maximizing power gains? This includes drivetrain, breathing, electronic, and other engine mods.
Thats it. There is nothing to really tune since everything should be set right and you don't have much to play with as it is. I would dyno it after the install just to check that the car was indeed making power and Air/Fuel Ratio wasn't going crazy anywhere.
The best investment you can make is a wideband gauge from AEM, sure its like $300 but its well worth it, cause it might save you from blowing your motor one day.
What I had on my 13psi setup, which you should not do.
AEM EMS
RC750's
AEM 3.5 Bar Map
3.15" pulley
It was more of an experimental project since no one knew sizes and specs for the 2.2l correct pulley sizes. Melted 2 Pistons and spun a couple rod bearings, so yeah, it didn't work out.
AEM EMS
RC750's
AEM 3.5 Bar Map
3.15" pulley
You might also want to consider budgeting a new clutch. Mine started slipping 2 months after I installed the charger. Get it on the dyno to check your a/f and to see if your clutch is holding at the higher rpms.
Silver S2k4 --Everything that comes with the kit, and don't touch anything else. This is to run smoothly and safely, if you want a little more kick, get the 7lb pulley, vafc, 550's and someone with a dyno and brains.
