Adding HFC
Old Sep 3, 2010 | 10:22 AM
Kremlin's Avatar
Default Adding HFC
I have a CTSC /w AC and HKS Hi Power exhaust. If I add a berk high flow cat, do I need to retune, or anything of the sort? I'm using the stock Comptech kit (no engine management) which IIRC just had some sort of rising rate hack to manage AF ratios. It's been a while since I looked at this stuff at all, so I'm a bit foggy on the details.
Old Sep 3, 2010 | 10:24 AM
Revenge's Avatar
I think you should be OK
Old Sep 3, 2010 | 11:45 AM
dsddcd's Avatar
Yeah, that won't make enough difference to mater unless you have a terrible feedback loop.
Have you checked your AFR's?
Old Sep 3, 2010 | 12:35 PM
Kremlin's Avatar
Thanks. I haven't checked my AFRs in a VERY long time..
Old Sep 3, 2010 | 09:10 PM
00S2K01S4's Avatar
From my exp, I also have a ctsc w/ ac and after installing my asura hfc, my afr was slightly leaner. I have a wideband installed so it was easy to adjust it back to what it was before.
chuhsi
Apr 4, 2008 11:59 PM
BerlinaBayRidah
Jan 15, 2006 09:52 PM
BerlinaBayRidah
Jan 11, 2006 01:22 PM
St3alth
Jan 6, 2006 02:16 PM
frankyknuckles
Mar 6, 2003 02:50 AM
