Adding a smaller pulley to a CTSC
Old Apr 10, 2012 | 12:42 PM
s2konroids's Avatar
Default Adding a smaller pulley to a CTSC
I know the boost goes up with Rev's, if i upgrade to a smaller pulley which is either 1 or 2 psi more will it just bit 1 psi at each interval more or does it not work like that? e.g
previous
3k 2 psi
4k 3 psi
5k 4 psi
6k 5
7k 6
8k 7
9k 8
But after a smaller pulley what does it change to, just 1 more psi at each stage?
Thanks
Old Apr 10, 2012 | 03:35 PM
Moddiction's Avatar
Former Sponsor
The max psi per pulley is at redline. It will be much less of a boost gain lower down in the rpms. To get significantly higher psi mid range etc you would have to make a big jump up in boost.
Old Apr 11, 2012 | 03:51 AM
Sideways's Avatar
It's very linear. 2 psi at 9000 rpm would be 1 psi at about 4500, 0.6 psi at 3000 rpm.
s2kseven
Jun 13, 2019 11:17 AM
branden2k
Nov 5, 2013 06:49 PM
vadik_s2k
Aug 11, 2011 11:42 AM
mrscbw
Aug 1, 2011 11:26 AM
Big Ben
Aug 14, 2003 12:12 PM
