Adjusting Internal Wastegate On Greddy
Old Aug 10, 2008 | 05:38 PM
TRBOKEV's Avatar
Originally Posted by SgtB,Aug 10 2008, 11:49 AM
I whent 3 complete turns and it put me around 5.5. I started at 10:30 and I just got back from my test run. I didn't pull the turbo completely out though. i just unbolted everything and flipped the-manifold turbo pair over in its spot. The oil relocator has to come off to get it all the way out, but it's just a matter of the two small mounting bolts, and the center hose and bolt at the engine. Now I have to go grind away all the crap that the junk downpipe is hitting. Also found out my mounting tab on the dp was sheared. I wish I would have gone ITBs.
So did this lessen boost creep or spiking in VTEC?
Do you have a boost controller to raise the boost back up?
Old Aug 10, 2008 | 06:29 PM
SgtB's Avatar
Didn't port it, just adjusted it. Greddy had it set at 9.5 stock, so I wanted to be able to turn it down on hot days. The truboost puts it right back at 10 when I want. I'm ALL stock except the kit. Never had spiking.
Old Aug 10, 2008 | 06:32 PM
ERL_S2000's Avatar
What type of boost control are you using. If you are using a boost controller then adjusting the wastegate is going to add/subtract the amount of time the external controller device can catch boost and control it.
Old Aug 10, 2008 | 06:35 PM
SgtB's Avatar
I'm using the truboost with the spring set to 6. I've never had problems with it spiking. The lower spring rate actually makes it safer as it is more prone to open now.
Old Aug 11, 2008 | 09:54 AM
Mr.Aqua's Avatar
I'm curious to see if you put a test pipe in there to see where that would bring your boost up to. If your at 5.5 PSI running off the spring I would think the test pipe with a free flowing exhaust would get you right about 10 psi.
Old Aug 11, 2008 | 12:03 PM
SgtB's Avatar
We'll see. I'm saving for a ton of parts right now. It should be interesting soon.
Old Aug 11, 2008 | 04:53 PM
JoeyBalls's Avatar
I remember the night I spiked to 15PSI The car f---- jumped off the line it was the ballsiest thing ever, the car was awesome, of course I was within milliseconds of blowing my motor
Old Aug 12, 2008 | 06:57 AM
TRBOKEV's Avatar
wow I have my spring pressure "SPR" setting to 3.5 on my tru boost with the cycle set to 35 for 10 or so pounds (on a cool morning) and 45 for more boost.
Old Aug 12, 2008 | 07:02 AM
TRBOKEV's Avatar
WOW so you were getting up to 9.5 pounds of boost with stock exhaust and stock cat?
Freaking Greddy, how damn hard is it to set these arms BEFORE they ship them to us? Now guys like you have to spend all this time adjusting the damn WG.
On a side not my low setting was seeing boost up to 10 or so pounds spiking a little over 12 this morning.. It was cool out though.
I was thinking of adjusting mine this last weekend but didnt but maybe I should have.
Forgottens2k
Nov 28, 2015 12:41 PM
RedSunS2K
Forced Induction For Sale
Sep 5, 2012 04:21 PM
guamie
Jun 13, 2012 03:38 PM
JPs_PITT_S2K
Mar 21, 2008 02:14 PM
