Advice on Lowering Temps
Old Jul 14, 2013 | 09:10 AM
jordannn93's Avatar
Originally Posted by Supradriver08
Man i am having the exact issue... and i live in houston. I cant drive mid day cuz of this heat...i dont know the exact temps im at but i know its way above normal (3-4 bars above normal)
I have a custom front facing turbo set up too...i just bought a koyo radiator and stock fans. so hopefully that will help my temps. next step for me is to buy a spare hood and cut the inserts out.
Most discomforting thing to see while driving is your coolant temps so high lol stupid houston/texas weather
What ems do you have ?
Old Jul 14, 2013 | 02:58 PM
Supradriver08's Avatar
Hondata flashpro...I was just too lazy to hook it up to see the temps. That was me cruising on the freeway. But as soon as I get to lower speeds it cools down a little bit. It fluctuates a lot in this Texas weather.
Old Jul 14, 2013 | 03:24 PM
TheMuffinMan's Avatar
Actually was about to start a thread on this.
On hot days I'll get warm AC and temps that start to creep up to ~205 which concerns me. I have a FullBlown Radiator + Mishimoto fan shroud + fans and it'll still hit that.
I've been considering going with the Spoon thermostat, fan switch, rad cap and bleeding the system (again) to make sure everything is good. Also think adding on a cooling plate and venting the hoot would help as well.
Any other suggestions?
Old Jul 14, 2013 | 06:09 PM
Suzuka_Joe's Avatar
205 is not something to be worried about. 225+ is
Old Jul 14, 2013 | 06:28 PM
herecomesboost's Avatar
Those are your cruising temps?!
Old Jul 14, 2013 | 06:47 PM
p0staboy's Avatar
I was having problems with my car getting really hot so I decided to bleed it using the billman method and it dropped my temps a lot
Old Jul 14, 2013 | 07:03 PM
redboost10's Avatar
If you decide on the fullblown radiator, just save a bit of money and get a mishimoto. It's the same thing.
Old Jul 14, 2013 | 08:24 PM
spdracerut's Avatar
Those temps are way high.... It looks like you're in the 239F range.
Old Jul 14, 2013 | 08:27 PM
spdracerut's Avatar
Are you guys doing anything to seal off the radiator? Simple foam trick should help a little bit. Also, check your A/C condenser and straighten out any bent fins.
http://www.motoiq.com/MagazineArticl...erheating.aspx
Old Jul 15, 2013 | 07:15 AM
siadam's Avatar
If you have an AEM your ECT calibrations are incorrect and reading high.
https://www.s2ki.com/s2000/topic/184...-calibrations/
