AEM 1052 "D" harness troubles
Old Dec 18, 2008 | 09:10 PM
EK9MAX's Avatar
Default AEM 1052 "D" harness troubles
Ok so i bought a AEM 1052 used from a member on here. He shipped me his entire engine harness aswell.
Plugging everything in, it looks like i'm missing the 4th connector on the AEM. It's the D plug.
Does there anything on the D plug that i need to run the car??? I know that i need D15 for my AEM boost solenoid.... but if i don't need anything else i'm just gonna solder a wire on that pin to make it work, rather than buying a whole harness plug set from aem....
Old Dec 19, 2008 | 04:15 AM
A.J's Avatar
A.J
Banned
No
Old Dec 19, 2008 | 06:04 AM
GDM S2K's Avatar
Originally Posted by A.J,Dec 19 2008, 08:15 AM
No
wrong.....
boost controller gets wired in there as well as other sensors you can use
Old Dec 19, 2008 | 06:42 AM
EK9MAX's Avatar
Originally Posted by GDM S2K,Dec 19 2008, 07:04 AM
wrong.....
but do i need those sensors for it to run????
the only addition sensors i'm adding are a uego which gets tapped into a different plug. and teh boost solenoid, which i'll just solder to D16 directly....
Old Dec 19, 2008 | 07:05 AM
GDM S2K's Avatar
boost solenoid you will need the xtra plug, you dont want to solder directly to the EMS
Old Dec 19, 2008 | 09:29 PM
EK9MAX's Avatar
i'll get a pin from an old harness i have lying around. But is there anything else in that plug tha ti need for my car to run? I'm wondering cause i asnt' supplied with one.....
Yaseen74
Feb 9, 2018 07:09 AM
rtboy10
Nov 3, 2011 12:52 PM
ekoms31
May 23, 2010 07:00 PM
phils2k
Apr 26, 2009 11:53 AM
