Aem boost solenoid issue?
Old Sep 15, 2009 | 03:10 AM
m R g S r's Avatar
i've never heard of valves dropping from revving a motor to 5000rpm.
Old Sep 15, 2009 | 04:53 AM
wadzii's Avatar
Banned
what i usually do is wire the 12v+ side of the solenoid to one of the spare HS outputs on the ems, and use that to control when the solenoid finally gets powered on. i usually set the hs output to turn the solenoid on over like 10% throttle and 1500 rpms, that way you never have to hear it.
and if you fubar valves on the 2step you're doing something seriously wrong.
antilag for a few sec to launch the car wont hurt anything at all... now if you're a moron and hold it on the antilag for 20 mins showing off, then yes you will **** shit up.
Old Sep 15, 2009 | 06:18 AM
siadam's Avatar
Originally Posted by Spoolin,Sep 14 2009, 02:20 PM
Devin Pearce from aem set it up that way when he tuned mine. It means you will be building boost off the wastegate spring only when using a two step setup. I think that should be plenty of boost for off the line but you definitely dont want to run a two step on the stock valve train.
That makes since.
I still don't see where that is an option though.
Old Sep 15, 2009 | 06:27 AM
wadzii's Avatar
Banned
he probably did what i was saying... used an hs output to power the solenoid
JspecVtec
Jul 27, 2015 11:14 PM
cmn
Oct 25, 2011 12:53 PM
s20004lifehomes
Feb 15, 2011 09:28 AM
jcss812
Jun 1, 2010 08:31 AM
AFs2k
May 1, 2010 02:22 PM
