aem ecu
Old Oct 3, 2011 | 08:41 PM
Stealth_SUX_'s Avatar
Default aem ecu
I've been looking on the forum and I am wondering can you hook up an innovative wideband to an aem ecu.. All I can find is people connecting an aem wideband. Reason is, I have the innovative wideband and I'm wanting to get the aem ecu for my greddy kit.
Old Oct 3, 2011 | 11:22 PM
s2knoob89's Avatar
Yes, you can connect the Innovative wideband.
Old Oct 4, 2011 | 12:22 AM
riceball777's Avatar
you can connect any wideband to an aem ecu. It wires in the same way you would wire an aem wideband into an aem ecu
Old Oct 4, 2011 | 08:17 AM
InductionPerformance's Avatar
Any wideband that has a 0-5v output and voltage scaling will work
Old Oct 4, 2011 | 11:24 AM
The innovative has the 5v output....
So I dont need any special harness to hook to the AEM.
Also while on im the subject.
I know with the greddy to boost over 10psi you need the greddy boost sensor because factory doesn't read past that amount. What is needed for the AEM.
I want to make sure I know everything I need before I switch to the AEM ecu instead of the Emanage.
Old Oct 4, 2011 | 01:31 PM
04Briggs's Avatar
here's a link to the instructions:
http://forum.aempower.com/forum/inde...c,21539.0.html
click on 10-6052 if you are getting a series 2 ems. Everything is plug and play from the old harness. There's instructions/diagrams for connecting aftermarket accessories. If you are installing the older ems, your temp gauge will not work. They have base maps on the forums and the software came with a base map for a supercharged ap1.
Old Oct 4, 2011 | 01:42 PM
04Briggs's Avatar
to set it up for the wideband, in aemtuner, click on "wizards" (tap at top) then "setup wizard". from there you can choose to use the innovate LC-1. You can set it up for your map sensor from there also. It's pretty user friendly.
Old Oct 4, 2011 | 01:46 PM
04Briggs's Avatar
you can download the software here for free:
http://www.aemelectronics.com/engine...r-software-61/
If you download the software and play around with it before you install the ems you'll know what products work with it. Still read the instructions and get it professionally tuned before you try to drive it.
Old Oct 4, 2011 | 01:48 PM
04Briggs's Avatar
I doubt you care, but you do know this is illegal in CA right? Make sure you keep your origional EMS and sensors or you will never pass smog.
Old Oct 4, 2011 | 02:28 PM
Thanks
Yea I know its illegal. And yea I'm keeping original to swap back in when I need to smog.
