AEM ECU rough tune to get to tuner
Old Sep 22, 2005 | 11:04 PM
skibum's Avatar
Default AEM ECU rough tune to get to tuner
I just finished installing a turbo kit on my car and the shop that will be tuning my car is about 150 miles away. If I run stock injectors and stock ECU it runs too lean, but the car won't run with the aftermarket injectors and ECU. If anyone has anything that might function well please PM or email it to me (projekt8e@gmail.com). Like I stated, it's a 2004 S2k with 1000cc injectors and AEM ECU. Hope thats enough info to get it going. This is actually Skibums roommate and I am just using his account to get his car running.
Thanks!
Old Sep 22, 2005 | 11:44 PM
Ragingazn's Avatar
woah.. 1000CC injectors? damn. how many pounds of boost are you goign to run?
which tuner dyno shop are you going to bring it to?
Joe
Old Sep 23, 2005 | 03:33 AM
Tinker219's Avatar
http://www.lovefab.com/cody/Codys%20...uego.V1.11.cal
Fired my 1000cc injectors RIGHT up, 27mpg. Use at your own risk, just because its running my car doesnt mean itll run yours safely enough to boost!
If you need to change injector size,
open the fuel table
right click, change injectors/size.
change from 650cc at 50psi
to 1000cc at 50psi, and it should lean it out IF need-be.
Old Sep 23, 2005 | 09:23 AM
skibum's Avatar
awesome, thanks for the map, I will monitor it to make sure it isn't destroying the motor. I'm not sure of the name of the tuner he is using but I'm sure he will post something, under this account obviously Thanks again!
Old Sep 23, 2005 | 09:28 AM
skibum's Avatar
Science of Speed in Tempe, AZ only tunes AEM and they are very familiar with s2k's and NSX's.
After a new head gasket I will probably run 10-12psi
Old Sep 23, 2005 | 03:59 PM
skibum's Avatar
skibums roommate reporting live...shit aint starting....at all. Thanks for trying though.
Old Sep 23, 2005 | 04:39 PM
timg's Avatar
Which ECU do you have? The 1052 or the 1012? The maps are NOT interchangeable and one will not start on the other.
Tim
Old Sep 23, 2005 | 04:47 PM
skibum's Avatar
Its the 1012. Which do you have?
ghosta9
Jun 24, 2015 07:27 AM
S2KVee
Jan 7, 2015 01:41 PM
S2KVee
Sep 16, 2014 03:18 PM
gusrock77
Sep 8, 2009 08:49 AM
Dsgs2k3
Apr 8, 2006 11:34 AM
