Aftercooler pump.
Old Sep 23, 2005 | 11:51 AM
spoiled@21's Avatar
Default Aftercooler pump.
Is there any better place i.e. in the enigne bay to tap into something to energize the solenoid. I already have my escort 8500 and srx laser jammer and uego wired into the fuse box. I don't know that it will take anymore current draw.
thanks,
Alex
Old Sep 23, 2005 | 12:43 PM
skibum's Avatar
Do you have the Passport wired under the hood or at the kick panel? Wiring the pump to the fuse box under the hood on the passenger side is clean, quick, and easy.
Old Sep 23, 2005 | 03:17 PM
folex187's Avatar
You really aren't sending much current to the relay at all. All you are getting from the fuse box is a signal to turn the relay on. It is the same as the amount of output your headunit would send to the amp via the remote wire.
Old Sep 23, 2005 | 05:32 PM
Asura's Avatar
T-tap any 12V wire switched with ignition.
Old Sep 23, 2005 | 06:19 PM
spoiled@21's Avatar
thanks guys.
warbucks
Apr 4, 2014 01:20 PM
warbucks
Apr 2, 2014 05:33 AM
eastonh477
Oct 28, 2012 04:07 AM
jtime
Nov 30, 2006 04:13 PM
FRFR
May 23, 2004 07:59 PM
