AEM EMS
Old May 13, 2007 | 06:37 AM
Spec_Ops2087's Avatar
Default AEM EMS
I know the AEM EMS has a built in 2 step limiter. My question is, how do you wire it up to activate it? Is there some ground wire in the EMS that I must tap into and wire a switch to it or something? I'd be doing this for launch control if anyone needs to know
Thanks
Jonathan
Old May 13, 2007 | 07:26 AM
John_Z's Avatar
It's easy. Go to Setup>Rev Limits>2Step Rev Limiter>Options - 2Step Rev Limit
Switch Always On
Fuel Cut *whatever rpm you want*
Ignition Cut *whatever rpm you want*
Ok below VSS *whatever mph you want*
Retard Rev *whatever rpm you want*
Have fun with the flames
Old May 13, 2007 | 07:48 AM
Well I know how to do that part
Question is, how do I wire up a switch for it to turn it on and off at will without having a laptop handy?
Old May 13, 2007 | 07:54 AM
Actually now that I think about it.
If I set it always on, the setting "Ok below VSS" means it will only come on when the car is below that speed?
Old May 13, 2007 | 08:00 AM
John_Z's Avatar
Sorry for the oversimplification Yes, you will need a laptop to turn on/off this function. When it's on, it will only activate below your set mph. Mine is set at 5mph.
Old May 13, 2007 | 08:01 AM
John_Z's Avatar
No need to wire up any additional switches/wires etc too.
Old May 13, 2007 | 08:38 AM
Phillie's Avatar
Nice to know!
Old May 13, 2007 | 08:40 AM
Thanks, going outside to try it right now
Old May 13, 2007 | 08:44 AM
JohnZ, what did you set for your retard rpm?
Old May 13, 2007 | 08:58 AM
Well I tried the following:
Switch Always On
Fuel cut = 0rpm
Ignition cut = 5000rpm
Ok below VSS = 5mph
Retard rev = 12000rpm (this is what my stock limiter is at, I don't want to play with it without knowing what it is)
And it doesn't work
Any ideas?
