AEM EMS
Old May 13, 2007 | 07:48 PM
  #21
s2guru's Avatar
Spec_Ops2087 can anyone post a video ?
Old May 13, 2007 | 11:02 PM
  #22
chairmnofthboard's Avatar
What's the point for the 2step rev limiter?
Old May 14, 2007 | 02:24 AM
  #23
OGPackin's Avatar
Hey guys, when u run the 2step wizard what "level" do u have it set too...? thxs
Spec, what are ur final settings..? thxs bro!
Old May 14, 2007 | 07:37 AM
  #24
passmans2kny's Avatar
u use it for a better launch
Old May 14, 2007 | 01:32 PM
  #25
Spec_Ops2087's Avatar
Fuel cut 5500
Ignition cut 5000
VSS 5mph
Retard rev 4900
I'm also on a "hard" cut in the wizard.
Old May 14, 2007 | 01:43 PM
  #26
OGPackin's Avatar
Originally Posted by Spec_Ops2087,May 14 2007, 04:32 PM
Fuel cut 5500
Ignition cut 5000
VSS 5mph
Retard rev 4900
So "level 10-hard cut" ?
I have my map saved to my pc, and im trying to make the changes "offline" but the values arent changing...? Do you have to be connected to the aem to make the changes? thxs!!
Old May 14, 2007 | 04:53 PM
  #27
You should be able to change the values in offline mode, then save the changes, finally upload the new map to the EMS
Old May 14, 2007 | 05:01 PM
  #28
OGPackin's Avatar
Its weird! My values are set to "0" When i change the Fuel Cut value to "5500" then tab to the Ignition value the Fuel Cut value changes back to "0" No matter what i put the minute i tab off it changes back to "0"
What am i doing wrong? thxs for your help!
Old May 14, 2007 | 05:03 PM
  #29
AusS2000's Avatar
Try hitting return instead (or before) Tab. Bit of an interface glitch I think.
Old May 14, 2007 | 05:05 PM
  #30
OGPackin's Avatar
UGH! That was it Aus! Thxs bro! This has been driving me nuts for hours...lol
