aem ems help pLz!
Old Apr 9, 2011 | 09:56 AM
bois2k's Avatar
Default aem ems help pLz!
tried switching to my 91 octane tune and now car wont start i have the calibrations saved on my email can someone tell me how to install them so i can get my car going again
Old Apr 9, 2011 | 10:25 AM
Blucky87's Avatar
you need help installing the cal files to your ecu?
series 1 or 2?
Old Apr 9, 2011 | 10:35 AM
bois2k's Avatar
series 1
Old Apr 9, 2011 | 10:41 AM
bois2k's Avatar
when i click the files it pulls up the ems but doesnt seem to work might have a difrent version of the aem pro then the calibrations??
Old Apr 9, 2011 | 11:09 AM
Blucky87's Avatar
have you tried using aemtuner instead of pro? they don't even update pro anymore..
Old Apr 9, 2011 | 11:13 AM
bois2k's Avatar
where can i download aem tuner v1.9?
Old Apr 9, 2011 | 11:20 AM
bruthaboost's Avatar
Go to the aem forums. You can download the manual for the ems. It will be a sticky. In it are detailed instructions on how to load a cal file from your laptop to the ems.
Old Apr 9, 2011 | 11:33 AM
bois2k's Avatar
well looks like i got it on there befor my fuel pump wouldnt prime then i uploaded it and fuel pump turns on but when i try to start it only turns over once then does absolutly nothing
Old Apr 9, 2011 | 11:43 AM
Try the base map aem provides just to check if your car will start. It's a decent base map. If you have your stock injectors, throw them on, if not, you'll have to set the ems up for your size injector, fuel pressure, etc. The manual walks you through it (pg 61 of the ems users guide)
Old Apr 9, 2011 | 11:49 AM
bois2k's Avatar
got the car to start needed a battery jump idles fine now how can i check that its on the map that i uploaded
