AEM EMS Issues
Old Oct 14, 2006 | 11:16 PM
kane.s2k's Avatar
Default AEM EMS Issues
Ok, today's attempt with my trying to fire the car up failed for some reason.
My AEM EMS does not connect nor does it fire the injectors, provide spark, or do anything UNTIL I crank it over.
Before cranking but key turned all the way (12+V power, AEMPro via serial cable, all wiring is correct):
a) Does not connect to AEMPro...says it's offline.
b) Fuel pump does not prime.
c) Boost control solenoid does not click
Once I'm cranking:
a) Connects on the AEMPro (eliminates the possibility of the serial cable being bad)
b) Doesn't spark
c) Doesn't spray fuel
d) Fuel pump is pumping
Stop cranking:
a) Goes offline again
I have version 1.19 loaded. I am going to try going back to 1.11 but I dont see why it wouldn't connect. This AEM EMS used to work fine so I'm hoping it's not a bad unit.
Old Oct 15, 2006 | 06:30 AM
jbotstein1's Avatar
Jeepers. Who does Kane go to when he is having problems? I hope you get it figured out. It sucks to be so close to having it back and have it not fire up.
Old Oct 15, 2006 | 07:03 AM
Kwando's Avatar
check the 15a ACG fuse (fuse box under the hood), mine blew after i removed my FMU... i had the same exact symptoms... LMK if that fixes the problem
Old Oct 15, 2006 | 08:21 AM
hboy7777's Avatar
i just punched mine when it did that and it works now. lol
Old Oct 15, 2006 | 12:50 PM
fperra's Avatar
Do you have the injector driver box hooked up? If so, did you intercept the injector signals from the ems and pass them through the P&H box? Also, do you have a good groung to the P&H box?
Old Oct 15, 2006 | 07:31 PM
Elite Performance's Avatar
when we did a k20 ek with ems a few weeks back i had the same issue the ems was not connecting for some reason....
i checked all the basics then i disconnected the battery and the ems and connected the battery back and re laoded the ems again and it worked for some reason....
Old Oct 15, 2006 | 08:56 PM
kane.s2k's Avatar
I just didnt have enough time to check it well enough. I had checked every single fuse under the dash including the ACG and there weren't any blown. Went home and posted it here so I get suggestion on stuff to look for tomorrow since I was tired.
The cause of it was another ACG fuse under the dash. It's a 15amp fuse. No clue why it was blown at all.
Old Oct 15, 2006 | 09:24 PM
Scorpion's Avatar
So you are good now then?
Old Oct 15, 2006 | 09:31 PM
kane.s2k's Avatar
Yea except I've come into other issues. My afr stays at 7-8 even though it's lean as can be. The map I have rescaled is extremely lean and I richened it up 13% all across but I don't know where it is at because I cannot see the afr's correctly.
Set the voltage to 3.94v with a 1.28gain with the UEGO unplugged and no luck.
I will admit I didnt spend any time on debugging. I spent almost all of today trying to find out where to dispose of 9 gallons of a year old gasoline.
Old Oct 16, 2006 | 07:42 AM
Tinker219's Avatar
Rashed make sure your AFR numbers are not in different units, such as methanol or ethanol.
To check, go to Configure>Units>AFR> and check Gasoline. Sometimes things go quirky when electronically sending maps everywhere.
