AEM EMS Users
Old Jun 14, 2009 | 01:34 PM
RAIN H8R's Avatar
Thumbs up AEM EMS Users
Well its mid June and we FINALLY have some humid weather in WI. So I would like to get my air conditioning 100% working properly. It seems to not work when Im at idle only... Nothign is consistant. If someone could post up there settings it would be greatly appreciated, or maybe a PM if you do not want to share with the world.
Here are my settings.
A/C Min speed 400 RPM
A/C off above TPS 80%
A/C on delay 1.03 seconds
Idle A/C load comp 5.86%
A/C request input Switch #6 Gnd=On
A/C CLutch LS6
A/C Fan speed LS8
Rad Fan Disable
Old Jun 14, 2009 | 02:32 PM
300sx's Avatar
Originally Posted by RAIN H8R,Jun 14 2009, 01:34 PM
A/C off above TPS 0%
There's your problem.
Mines at 89% but you just want it up there where it'll kick off before WOT. Suprised you have any cold air at all
Old Jun 14, 2009 | 02:38 PM
RAIN H8R's Avatar
woops. sorry that is supposed to be at 80%! Ill edit my post. All other numbers are correct.
Old Jun 14, 2009 | 05:03 PM
bagherra's Avatar
I hope this isn't a stupid question...you have to set your AC with AEM? Uh oh...if so, I didn't know that.
Old Jun 14, 2009 | 05:35 PM
300sx's Avatar
It's already setup in the basemap bagherra.
Rain H8r, all of your settings are very close to mine. Shouldn't be a problem in the settings. You can watch the parameter to see when your compressor clutch is turning on/off, maybe watch that and see if your compressor is doing what it's supposed to...
Old Jun 14, 2009 | 06:46 PM
bagherra's Avatar
Whew...thanks. It's starting to get hot out.
Old Jun 15, 2009 | 06:47 PM
RAIN H8R's Avatar
Good call, Ill watch more carefully when I fiddle with it next time...probably tomorrow after work.
Thanks!
Old Aug 10, 2009 | 10:06 AM
RAIN H8R's Avatar
Well, two months later and my AC still does not work. I have all the settings back to the basemap settings with no luck. What did you mean by checking the parameter of the compressor? I can see that its spinning with the pulley so I would think the air should be getting colder, but its not. Im doing all my testing while at idle by the way.
Any ideas?
Old Aug 10, 2009 | 10:57 AM
camuman's Avatar
did u verify there is pressure in the lines? when you turn on AC, do you hear clutch engage? do you see revs dip slightly?
if all settings are right in aem, i would lean towards a physical malfunciton on the AC system not to do with the aem ems.
Old Aug 10, 2009 | 09:54 PM
RAIN H8R's Avatar
The compressor "clicks" on. The revs change, and nothing...at idle, or sometimes at random points. It worked at cruising speeds on the freeway, but 5 minutes later it tuned off on its own. I think its an electrical issue.
