aem fuel pressure regulator
Old Nov 16, 2007 | 07:54 PM
syellow's Avatar
Default aem fuel pressure regulator
Does anyone have the AEM FPR? I ordered mine just a minute ago. I couldn't tell by the picture if it had a place to add a gauge. Does it have the hole for a gauge, or do you have to get an inline gauge? And if it is inline, does the gauge go on before the regulator or on the return line? Thanks
Old Nov 16, 2007 | 08:08 PM
Spec_Ops2087's Avatar
You need to tap the fuel rail afaik
Old Nov 16, 2007 | 08:22 PM
syellow's Avatar
really? There is now other way to do it? I'd rather not tap into the fuel rail, can't I just run an inline right after to fuel rail?
Old Nov 16, 2007 | 08:28 PM
You could I would think.
But the FPR doesn't have a hole on it for you to screw into.
Old Nov 16, 2007 | 09:01 PM
syellow's Avatar
Cool Thanks. That's what I needed to know. I just need to find out now if I can run an inline! I don't have a tap and die set so....
Thanks again
Old Nov 17, 2007 | 05:04 PM
AusS2000's Avatar
You mentioned running an inline on the return. This is not the place to attach a gauge. The return is the low pressure bleed off the FPR and will not tell you anything.
A tap and die kit can be picked up for a few bucks and is what you need.
Old Nov 17, 2007 | 06:22 PM
syellow's Avatar
Cool, I'm about to order the tap and die kit. How do you do it and where on the fuel rail do you tap it? Do you just drill into it and make new threads? I never used a tap and die kit before. Thanks
Old Nov 17, 2007 | 06:40 PM
AusS2000's Avatar
You need to know what sort of thread the gauge has and fins a suitable location. Front end of the rail is good I hear.
For each tap there is a recommended drill size. I look mine up on web sites. Google will help. You drill the hole, then run the tap through. Use some teflon tape on the thread and screw it in.
Old Nov 17, 2007 | 08:06 PM
Sideways's Avatar
The easiest is just tap the rail.
Chiung
Feb 23, 2016 07:30 AM
MugenAP2
Apr 17, 2013 10:30 PM
9krevvin
Dec 3, 2011 08:50 PM
Ap2spoonf20c
Jun 7, 2011 05:52 PM
batikan
Jul 18, 2006 05:11 AM
