AEM Fuel Rail
Old Apr 12, 2010 | 08:39 AM
dsddcd's Avatar
I used a glycerin filled guage made by Jegs, make sure you get a St-Stl body also
I tapped my fuel rail with no issues, however you need to tap the firewall side if you tap the top of the rail to prevent rubbing. Sorry Again Kevin.
https://www.s2ki.com/forums/index.ph...f=142&t=702293
Old Apr 12, 2010 | 09:30 AM
siadam's Avatar
Originally Posted by D1sclaimer,Apr 12 2010, 08:00 AM
I agree with you on this, but with the InlinePro rail, you can throw the stock fuel rail cover over it so you can't see it.
Another thing that I would have rather had is 10AN inlets like the Full Blown rail. The IP one is 8AN.
I'm not sure if the AEM rail allows for the use of the cover or not, it's a new part from what I've seen, so hopefully yes.
If not, it's really not a big deal.
Old Apr 12, 2010 | 09:53 AM
D1sclaimer's Avatar
What size fuel line are you running? I think on the AEM website it said that the inlet is 6AN.
Old Apr 12, 2010 | 11:24 AM
siadam's Avatar
factory.
Old Apr 12, 2010 | 11:25 AM
siadam's Avatar
AEM High Volume fuel rails feature a 1/2-inch fuel bore to support fuel flow for applications up to 1,000 horsepower. This large bore also dampens backpressure pulses created by larger injectors and works perfectly with stock injector sizes. An additional 1/8th NPT port is included to accommodate a nitrous set up or fuel pressure gauge. A custom fuel line fitting is included for the factory fuel line, and the ends of each rail are pre tapped to accept -6 AN or 9/16”x18 fittings for users who want to use custom fuel lines.
I should be ok.
Old Apr 16, 2010 | 09:59 AM
siadam's Avatar
Rail came today, looks nice..i'll have pics of it installed today/tomorrow.
Fraley
Jun 19, 2017 10:21 AM
Tom@inlinepro
Forced Induction For Sale
13
Oct 31, 2011 04:53 PM
red@9k
Oct 31, 2011 10:17 AM
razzele
Jul 19, 2011 08:48 AM
hypforlife32
Jul 28, 2010 09:08 AM
