AEM Methanol Injection
S2ki Team,
I'm working on installing the AEM Meth Kit and I'm undecided on how to mount the tank in the trunk. I've stripped the carpet out of the trunk and am peering around, no easy choices. I am hoping to use some existing holes rather than drilling and risking the formation of rust. For that matter, I am hoping to avoid self tapping screws. I think I may buy some 'L' brackets, modify them, and trim the carpet to bolt the tank up. Anyone have any experience with this?
Just finished constructing mine. I'm using the 1 gal tank. I'm stealing your setup with some vertical posts to mount the smaller tank vertically. I"m also using 10mm thick ABS plastic.
Did you find any lag with the pump being so far from the nozzle? I suppose it probably doesn't matter much since neither side seems like it would stay pressureized w/o a check valve. I'm going to try to tuck it behind the bumper at the lower left hand corner of the radiator using existing holes and a plastic bracket I made.
be careful with the Check valve, I had to remove mine it was causing all kinds of problems.......................
my pump is mounted in the trunk and I have a flow guage, delay is minimal, really non existent
Just cant effectively tune around that. Still cant really with a 2 sec delay. Wish I could figure out how to get instant like response, I could then up the boost and be making quite a bit more power.
Originally Posted by geists2k,Jul 7 2010, 11:01 PM
Why did you go with the diesel sized giant tank lol? The small version is more than enough.
Moddiction
Apr 23, 2014 10:38 AM
JoeyBalls
May 26, 2010 10:09 AM
