aem methanol what size nozzle
Old Nov 29, 2012 | 06:32 AM
s2konroids's Avatar
Default aem methanol what size nozzle
I have a ctsc @ 13.5 psi circa 400 to 450 bhp at the crank with an aftercooler.
There are two nozzle so I presume the smallest is the best one to use?
Old Nov 29, 2012 | 10:05 AM
s2000Junky's Avatar
The small one wont do shit AJ, it would be virtually pointless. You should have got 3 total with your kit. Small/med/large. 140cc/330cc/550cc. If your going to spray mostly water, then I recommend the med. If your going to spray 50/50 or higher meth concentration then go with the large nozzle.
Did you ever get the kit to work? Never got a reply on your half a dozen other meth threads
Old Nov 29, 2012 | 11:17 AM
s2konroids's Avatar
Hi mate haha i know, i only got two jets with my nozzle looks like i have the newer kit which only comes with a medium and large nozzle.
No i think the controller malfunctioned />
I will just use the larger one then, as ill be running 40/60 meth water.
Old Nov 29, 2012 | 03:47 PM
s2k manic's Avatar
interesting so the medium jet is the way to go i drilled the small jet out a bit but smaller than the medium jet. wonder if i should switch back car was running rich on the 50/50 mix but was lean on the small jet should i run the medium jet and back off the fuel pressure?
Old Nov 30, 2012 | 06:13 AM
Deception's Avatar
I ran the largest size nozzle with a 70/30 meth/water mix, turbo @ 13psi
Old Nov 30, 2012 | 10:02 AM
s2000Junky's Avatar
This is about the ratio I ran as well with the large nozzle.
** AJ, More fluid = more cooling and detonation suppressant, but too much water isnt really a good thing, so calibration % between water and meth, plus nozzle size should be considered both. At 60% water I might stick with the Med Nozzle. Best thing to do is try them both on the dyno and see how things look.
Nik2k
Mar 27, 2015 11:17 AM
0piston
Mar 12, 2012 04:52 AM
S2KB00ST
Jun 5, 2011 08:45 AM
mys2k3
May 22, 2010 01:56 PM
sbrodacz
May 22, 2009 11:41 AM
