aem pinout and connector
Old Jul 13, 2008 | 03:13 PM
mys2k3's Avatar
Default aem pinout and connector
Has anyone else noticed that the back of the "D" connector (where the wires slide in) for the 1052 don't match the numbers on the paperwork. If you are looking at the back of the connector the top right hand corner has a number 1 and the left corner has a number 5, bottom right corner is a 13 and bottom left is a 16. According to the paperwork the bottom right should be D16 and it should be all by itself. On the back of the connector it shows 13. I went according to the paperwork which I'm hoping is right. Anyone else notice it?
Also wanted to know how to get one of the pins out after it has been put in the connector? I put one in the wrong opening and now need to get it out if possible.
Thanks.
Old Jul 13, 2008 | 03:14 PM
PeanutButter's Avatar
Lines up 100 percent on my end, turn te connector around
Old Jul 13, 2008 | 03:29 PM
mys2k3's Avatar
I did turn it around and just had to count back. I just followed the numbering on the paperwork. Was wondering if anyone else noticed this and wanted to make sure I had it right. Any input on getting the pin out of the connector?
Old Jul 13, 2008 | 03:55 PM
AusS2000's Avatar
I found it to be correct and wired up my boost control correctly.
To remove a pin you need to pull up the white plastic lock with a pair of pliers and then just finagle the pin out.
Old Jul 13, 2008 | 04:27 PM
squirrels2k's Avatar
all of my pin holes and numbers were correct.
Old Feb 10, 2011 | 01:34 PM
Pawan's Avatar
I spoke w/AEM tech support and they said to ignore the number on the connector and follow the paperwork. Looking from the wire side.
My connector also said 13 when it should be 16 according to paperwork. I will post an update once installed.
Ws2006
Dec 12, 2006 07:17 AM
