Aem series 2
Currently AEM series 2 firmware version 3.2 is broken. The ECU can't pickup the vehicle speed. Display remains at 0.0 mph at all speed. You can't set the boost by gear wizard due to the no vehicle speed value. Can't boost by speed also. If you set a constant value for boost by speed it works, but can't vary boost by speed.
Probably have to wait for an update to see if they fix this issue.
Boost by gear is not recording the gear ratios when you save it so it is not functioning.
Originally Posted by s2knoob89' timestamp='1378646110' post='22767176
[quote name='indi00' timestamp='1378604959' post='22766872']
[/quote]
Good to know. Hadn't actually tested it on the road just pulling it in/out of the garage. Thanks
