Aem series 2
Old Sep 7, 2013 | 11:54 AM
admans2k's Avatar
Default Aem series 2
Want to do boost by gear and ecu won't pick up what gear I'm in, I tried the wizard and just has the same values for each gear?
Any ideas?
Old Sep 7, 2013 | 05:49 PM
indi00's Avatar
Currently AEM series 2 firmware version 3.2 is broken. The ECU can't pickup the vehicle speed. Display remains at 0.0 mph at all speed. You can't set the boost by gear wizard due to the no vehicle speed value. Can't boost by speed also. If you set a constant value for boost by speed it works, but can't vary boost by speed.
Probably have to wait for an update to see if they fix this issue.
Old Sep 8, 2013 | 04:06 AM
JoeyBalls's Avatar
The AEM series 2 is a complete piece of shit IMO
Old Sep 8, 2013 | 05:15 AM
s2knoob89's Avatar
It's not broke. You need to turn on the falling and rising edge on for input T3(speed sensor).
Old Sep 8, 2013 | 05:39 AM
s2knoob89's Avatar
Any ideas?
Boost by gear doesn't work. All of us use boost by speed.
Old Sep 8, 2013 | 07:24 AM
indi00's Avatar
Thanks! Overlooked that. Set the T3 Falling edge to on and now it works. Rising edge is off. Had it on and the speed was off in the upper 100's. I remember turning it off at one point and forgot to turn it back on. Doh!
Boost by gear is not recording the gear ratios when you save it so it is not functioning.
Old Sep 8, 2013 | 07:51 AM
s2knoob89's Avatar
Originally Posted by s2knoob89' timestamp='1378646110' post='22767176
[quote name='indi00' timestamp='1378604959' post='22766872']
[/quote]
Good to know. Hadn't actually tested it on the road just pulling it in/out of the garage. Thanks
Old Sep 8, 2013 | 08:11 AM
s2konroids's Avatar
So if if I set it up its actually functionality is actually working?
I'm confused lol.
Old Sep 8, 2013 | 10:57 AM
sohc_mshue's Avatar
Any ideas?
It recognizes my gears just fine
I think it did have trouble trying to set it up with the wizard though if i remember correctly.
Old Sep 8, 2013 | 01:48 PM
liquidgsr's Avatar
Did it work setting up on mine when you did it?
