AEM Tru BOost controller
Old Jun 4, 2009 | 12:30 AM
S2KB00ST's Avatar
Default AEM Tru BOost controller
I'm not 100% sure and just wanted to double check if the gauge will display boost without the boost solenoid (ie used as a boost display gauge)? I'm assuming that it should just work like a normal mechanical boost gauge without the boost control function if it is hooked up with a power source and the vac/boost signal. Am I correct?
Old Jun 4, 2009 | 12:58 AM
SgtB's Avatar
No. It will throw an error. You may be able to put a resistor across the solenoid wires, but I don't know for sure.
Old Jun 4, 2009 | 05:34 AM
AusS2000's Avatar
Why would you want to run it only as a boost gauge? There are plenty of other solutions for that and as a boost controller it is pretty good.
Old Jun 4, 2009 | 11:45 AM
S2KB00ST's Avatar
I have decided to use the solenoid and ems to control the boost and as a result the gauge is now redundant so I'm selling it alone without the solenoid. I already have a mechanical boost gauge to display my boost. A potential buyer is asking me this question so thats why I'm asking..
Old Jun 4, 2009 | 11:51 AM
S2KB00ST's Avatar
AEM states that its a fully standalone gauge and as such it can be used without the need of the AEM ems. Also as it comes with an onboard pressure sensor, I thought maybe is should read the vac/boost signal when its plumbed in?
Old Jun 4, 2009 | 11:55 AM
TRBOKEV's Avatar
Mine works fine without the solenoid but I only read vacuum and not boost cause im NA right now.
I do see .5 to .6 pounds of boost in VTEC though. LOL
Old Jun 4, 2009 | 12:57 PM
SgtB's Avatar
Weird. Mine just displays "S0L" and that's it.
Old Jun 4, 2009 | 01:15 PM
2big4aS2000's Avatar
the soliniod can be found for about $35 if you know where. it is the same as aem uses they just put there name on it.
Wydget
Jan 2, 2012 12:59 PM
s20004lifehomes
Feb 15, 2011 09:28 AM
nMeOnE
Mar 9, 2008 03:47 PM
kylemonster85
Jul 31, 2007 12:51 PM
batikan
Nov 17, 2006 12:03 PM
