AEM V1 Pro's?
Old Jul 16, 2012 | 01:15 PM
herecomesboost's Avatar
Default AEM V1 Pro's?
I'm attempting to configure a basemap for my turbo S2000 (AP2); I started with the base calibration for the S2000 (1052.V1.19). I'm unable to change any of the default parameters and because it's an old unit (AEMv1 1052), the sensor wizard doesn't contain the correct sensors for my application (omni 3 bar map sensor/id1000cc injectors). Any tips? TIA
-Kyle
Old Jul 16, 2012 | 01:17 PM
Also, I attempted to change the (uSec) dead times based on the voltages provided by ID, but as soon as I close the table, the defaults are restored.
Old Jul 16, 2012 | 04:59 PM
camuman's Avatar
Hit enter after changing each field. Hope they helps.
Old Jul 16, 2012 | 05:49 PM
passmans2kny's Avatar
save cal once u make the changes u want, it will indicate it was changed in red on the bottom of the program saying (cal changed)
Old Jul 17, 2012 | 03:18 AM
sohc_mshue's Avatar
I have never seen this happen before. For the map sensor you will need to enter in the calibration manually in the map sensor options. Also use the correct IAT and ECT sensor calibrations because they are wrong in AEM.
Old Jul 17, 2012 | 04:18 AM
Thanks guys. I was tabbing between fields; didn't realize that AEM requires you to hit 'enter' after each submission
I was able to successfully enter the calibration for the map sensor (omni3bar) and injectors (id1000).
Old Jul 17, 2012 | 04:21 AM
Subsequent question: Injector dynamics only supply the dead times for even voltages (8,10,12,14,16). Should I *smooth* the lines on the graphical representation? Or take an average between the dead times (between 8 and 10 to get the value for 9, for example) and enter the values in the tabular representation?
Old Jul 17, 2012 | 05:31 AM
On the drive in this morning, I thought of another way to get the odd numbered voltages corresponding dead times; AEMTuner has the ID1000 injectors listed in the wizard. My idea is to use the dead times from AEMTuner (odd numbered) and input them manually into my AEMPro calibration. Thoughts? Logically, all three of the aforementioned avenues should reach the same numbers.
Old Jul 17, 2012 | 07:40 AM
05TurboS2k's Avatar
Every once in a while I forget this tip and it takes me 5 minutes of getting pissed off only to remember this bit and laugh.
Old Jul 17, 2012 | 03:46 PM
I know the 2Step option isn't necessary for a basemap, but I'm curious what you guys are using as your settings. Moreover, do I need to input a value in each field? For example, I currently have the 2Step set with the following:
