AEM v2 startup cal
Old Jun 4, 2013 | 10:56 AM
siadam's Avatar
Default AEM v2 startup cal
I am switching to e85, and I recently picked up an AEM v2.
I've got my old maps when I was on pump/meth, however I know I'll need to add fuel to the startup cal's to limp it on a trailer before it gets tuned.
I was looking to see if I could get a map or 2 to verify some of my numbers before I fire this ol girl up.
Thanks in advance.
Old Jun 4, 2013 | 04:48 PM
siadam's Avatar
Bump.
Sent from my iPhone 5 using Tapatalk.
Old Jun 5, 2013 | 12:38 PM
siadam's Avatar
54 views.
Old Jun 6, 2013 | 01:25 PM
siadam's Avatar
Old Jun 7, 2013 | 09:25 AM
siadam's Avatar
Old Jun 7, 2013 | 12:00 PM
cuci591's Avatar
Dude I couldn't get any info when I was in the same boat. You deff want to let it idle so you can check to make sure all is good before you go on the dyno. Nothing sucks more than pulling the car off the dyno to fix something on your back just to put it back on the dyno. Long story short I called my tuner and he linked to my computer (Which was pluged in to my aem V1) And Tuned it from his house to drive and then I worked out all the kinks and took it to him and had it tuned.
Old Jun 7, 2013 | 01:26 PM
siadam's Avatar
I'm going to work on it tomorrow, I was hpoing to get a head start on it. It ran in September when I had swapped to my id2000's from my 1000's, so I guess I'll just need to use that map, and add some fuel in at idle.
Thanks for the reply though.
Old Jun 9, 2013 | 06:49 PM
siadam's Avatar
Took me about 3 hrs, but with a friends help we got it running.
Old Jun 10, 2013 | 05:38 AM
camuman's Avatar
did you just keep adding fuel until it idled? i wondered this too. also, what is stoich on the wide band with this fuel?
Old Jun 10, 2013 | 09:20 AM
Shftat9k's Avatar
If you were on Kpro I could help you out.
