AEMNET Gauge question!
I have a AEM V2 EMS and got a AEMNET Gauge (https://www.aemelectronics.com/products/gauges/digital-gauges/x-series/aemnet). Mainly wanted it for oil pressure only to realize that the V2 doesn't read oil pressure. So my question is If I buy a AEM oil pressure sensor and wire it to my EMS will the gauge work?
yes, oil press, oil temp and coolant temps can be pined into the aem, you should do this regardless just so you can log from time to time and do health checks on the car. the aem can gauge can read those inputs. you will likely have to configure the output channels in the gauge software to convert the volt signal to a numerical reading (ie 0-5v = 0-100, 2.5v = 50 psi, etc) so the gauge will dispaly the reading your looking for otherwise it will just show you a volt reading.
EDIT:
Think I found the correct software to edit the gauge, AEMdata?
Moddiction
Jan 18, 2014 04:40 PM
kleecker
Mar 6, 2007 01:51 AM
