AEMNET Gauge question!
Old Jan 21, 2022 | 11:21 AM
Initial.aj's Avatar
Default AEMNET Gauge question!
I have a AEM V2 EMS and got a AEMNET Gauge (https://www.aemelectronics.com/products/gauges/digital-gauges/x-series/aemnet). Mainly wanted it for oil pressure only to realize that the V2 doesn't read oil pressure. So my question is If I buy a AEM oil pressure sensor and wire it to my EMS will the gauge work?
Old Jan 23, 2022 | 10:30 AM
scottdh20's Avatar
yes, oil press, oil temp and coolant temps can be pined into the aem, you should do this regardless just so you can log from time to time and do health checks on the car. the aem can gauge can read those inputs. you will likely have to configure the output channels in the gauge software to convert the volt signal to a numerical reading (ie 0-5v = 0-100, 2.5v = 50 psi, etc) so the gauge will dispaly the reading your looking for otherwise it will just show you a volt reading.
Old Jan 24, 2022 | 07:25 PM
Initial.aj's Avatar
Thanks for the response! So I just need to get the sensors and wire them into the correct pins on my ecu. After that my gauge will pick up the voltage and I have to configure the voltage to the psi on the gauges software, and what software would that be, AEMTUNER or some other AEM software? (sorry if these are repetitive questons, wiring is not my strong suit as you can tell)
EDIT:
Think I found the correct software to edit the gauge, AEMdata?
forust
Aug 3, 2016 04:48 PM
winvargh
Sep 20, 2014 04:17 PM
Moddiction
Jan 18, 2014 04:40 PM
kleecker
Mar 6, 2007 01:51 AM
