AFR while revving normal? SOS stage 2 id1000
Old Apr 24, 2018 | 05:02 AM
Nick2t1me's Avatar
Default AFR while revving normal? SOS stage 2 id1000
Wondering if this 10 spot on the AFR is normal while revving the motor. Check out the attached link
Old Apr 24, 2018 | 11:27 AM
AP1Chief's Avatar
Accel tip is rich
Old Apr 24, 2018 | 01:17 PM
meatbag's Avatar
Some of it is decel settings some of it is your async delay time
Old Apr 24, 2018 | 01:37 PM
Nick2t1me's Avatar
Really appreciate the input guys now nothing has been changed tuning wise through the haltech , can it be something mechanical or does it lay with in the ecu, is there something I can do to correct the issue or is this a job for my tuner? Another note to add is I had a bad primary o2 and then I wired the wideband into the ecu , before the wideband with the bad o2 I had crazy lean and rich afr’s. It’s stabilized I would say now but seems to spike rich like the video shows.
Old Apr 25, 2018 | 02:27 AM
RolanTHUNDER's Avatar
How did you know you had a bad primary o2? did you pull a code during diagnosis or just notice symptoms?
Old Apr 25, 2018 | 04:22 AM
Nick2t1me's Avatar
Diagnosis with my tuner via emails found out the o2 was giving erratic readings to ecu
Old Apr 25, 2018 | 05:33 AM
Oh I see. did the car exhibit any odd behaviour as a result of those erratic readings like random misfire, etc?
Old Apr 25, 2018 | 06:25 AM
Nick2t1me's Avatar
So there were no misfires , it just ran extremely rich under WoT resulting in very sluggish power output, it’s as if someone turned off the supercharger and it was running n/a vehicle still boosts to 10 psi no problem just sluggish due to the AFR
Old Apr 25, 2018 | 09:24 AM
s2000ellier's Avatar
the haltech doesnt use the the factory o2 sensors for anything
Old Apr 25, 2018 | 11:40 AM
Nick2t1me's Avatar
it uses the primary o2 or wideband there is an option to enable which one you want to use
