AFR's between warm and cold difference
I have a comptech fmu laying around as well so I will see if that helps maybe. Only thing is it will cause pre vtec wot to be super rich I would think since it raises fuel pressure everywhere not just vtec wot.
Originally Posted by Moddiction,Oct 14 2010, 12:20 PM
But really normal for 10-15 degrees? I could understand like a 30-40 degree difference causing 1.5-2 point on the afr but 10-15 degrees seems nuts.
Or try out one of those new SOS or CT FVM piggy back devices, there is no adjustability like a vafc but it would likely be a benefit for you at your boost level and circumstance.
Originally Posted by s2000Junky,Oct 14 2010, 05:41 PM
Yeah nothing wrong, this is what happens. Its always leaner in the morning too, but after about 20-30min of driving around and getting things nice and warm you will see your afr settle down another .5 or so. I see aprox one full point from 11:5 to 12:5 from summer to winter temps on the same tune. Crank down that fpr to compensate.
so if your prevtec but only making 1psi of boost, then it raises fuel pressure at the rate it does based on 1psi. and as boost increases it will continue to raise fuel pressure even more.
But when you adjust the comptech fmu it richens up everywhere not just in boost. So makes it super rich wot before vtec! I had it in for a little while before and vtec was good but pre vtec was pig rich and bogging down.
Originally Posted by camuman,Oct 14 2010, 06:21 PM
it raises fuel pressure based on boost
