aftercooler
Old Jan 21, 2006 | 08:17 AM
ayS's Avatar
ayS
Default aftercooler
i just checked my water/coolant in my aftercooler and it was pretty low. im wondering if this is what's causing some weird noise coming from under my hood. i'll keep everyone posted. anyone know if it might of damaged anything?
Old Jan 21, 2006 | 12:58 PM
goowattjuy's Avatar
Not the thread jack, but do you find it necessary to have an aftercooler with the Comptech S/C? Is it a must have item or will your car run fine w/o it?
thanks
Old Jan 21, 2006 | 02:10 PM
ayS's Avatar
ayS
thanks
you would be fine. but if you plan on running higher boost i would always recommend it. also, the term running cooler is always better then running hotter, especially if you are FI.
Old Jan 21, 2006 | 02:20 PM
goowattjuy's Avatar
Did you upgrade your clutch as well? If so, which clutch did you go with?
Old Jan 22, 2006 | 04:47 AM
SC-S2000's Avatar
I ended up upgrading my clutch and for right now i am running the ACT street disc.
One thing you should be carefull of is the rest of the drive train which i am dealing with know.
In september I blew the rear CV of the prop. shaft and the less then a week ago my trans blew. so my word of advise is if you dont want to fork out several thousand dollars like i didnt but got forced to, Id drive easy.
Old Jan 22, 2006 | 07:10 PM
ayS's Avatar
ayS
i just put more fluid in my aftercooler, and everything is back to normal again.
s2kseven
Jul 17, 2012 06:54 AM
jojipoji
Feb 17, 2012 12:04 AM
molotovsoldier
Jan 31, 2011 08:19 AM
John_Z
Jan 31, 2006 04:08 AM
r_duff
Aug 29, 2005 10:59 AM
