Aftercooler pump stopped working
Old May 27, 2006 | 12:49 PM
revhi's Avatar
Default Aftercooler pump stopped working
I noticed my aftercooler getting hotter then normal the past few months. I was cleaning the car today and noticed that I dont hear the pump with the ign on position anymore. Last I recall, it was setup to come on with the key in the on position and if you open the fill cap you can see the water moving fast.
Its not doing anything now. I believe its tapped into the air pump fuse which I check and is fine.
Anyone else ever have a Comptech aftercooler water pump go bad? If so where to get a replacement. Im sure Comptech will take there sweet old time getting one out to me.
Old May 27, 2006 | 12:54 PM
markS2kcU's Avatar
And the white wire that goes to the fuse board is that ok?
Is it getting power down at the pump, I'd be checking that down there the with the multi meter first.
Old May 30, 2006 | 01:21 PM
blackfx35's Avatar
Any luck with this...I may have the same problem.
Old May 30, 2006 | 04:08 PM
revhi's Avatar
There was corrosion on the relay terminals. Cleaned them off still no good. Gave the pump a couple taps and its working again. Im going to order another one to be safe.
Old May 30, 2006 | 07:09 PM
blackfx35's Avatar
thanks...i remember my battery died once because my water pump never stopped even after i turned off the ignition....by the way, does your aftercooler feel icy cold or warm when everything's working properly?
Old Jun 14, 2008 | 01:02 AM
DSKC's Avatar
I might have a faulty pump as well, is htere anywhere I can find the wring diagrams for the pump so that there is a way to check the connections
Old Jun 14, 2008 | 09:25 PM
nightcrawler7188's Avatar
i replaced my relay and it came back to life instantly. cause i opened it up and the inside was all nasty looking too
Old Jun 14, 2008 | 10:45 PM
DSKC's Avatar
where did you buy the relay from?
do you have a part number?
the one I got on mine is a BOSCH 0-332-019-110
but cant find it anywhere
I hope its not the pump that's bad, the wiring is all correct, checked all connections, the relay makes ONE "Tick" noise when the ignition is switched on then not a peep, while the pump remains completely silent
Old Jun 15, 2008 | 10:47 AM
Soul Coughing's Avatar
have you taken a volt meter to the relay and seen if the pump is getting power?
Old Jun 15, 2008 | 12:32 PM
DSKC's Avatar
aparently the relay is fine, my coolant pump on the other hand... is toasted
