Aftermarket Knock Detectors
Old Feb 11, 2010 | 02:37 PM
CourageOO7's Avatar
Default Aftermarket Knock Detectors
Hey guys, I'm going to be getting in quite a bit of track time this coming season. I tuned my car on a street using the AEM EMS but it's one thing to street tune and drive around at low rpm 90%...it's another thing when the car lives above 5500rpm.
So tuners, do any of you like using the aftermarket knock detectors available? If so, do you have a preference?
I think I like the Knock Link because it's visual and I can rent a dyno and spot knock instantly. Has anyone had success with any of these? What other options do you know of?
Thanks, as always!
Knock Link:
http://www.rallitek.com/liknse.html
MSD:
http://www.jegs.com/i/MSD-Ignition/121/896...roductId=748342
Turbo XS:
http://www.turboxs.com/more_info.php?ID=212
Old Feb 11, 2010 | 02:53 PM
spectacle's Avatar
Interesting. Can any of those be fed into an ECU for correlation?
Old Feb 11, 2010 | 02:58 PM
CourageOO7's Avatar
The Knock Link (and I think MSD) have 0-5v outputs...so, yes...We could theoretically program the AEM to look at auxiliary input X and if the voltage rises above whatever turns the light red, retard timing.
Something like that. I THINK would work.
Old Feb 11, 2010 | 04:24 PM
RacerXI's Avatar
Don't forget the ole trusty http://www.jandssafeguard.com/safeguard.html
Old Feb 11, 2010 | 05:05 PM
Ian300D's Avatar
Originally Posted by RacerXI,Feb 11 2010, 05:24 PM
Now this looks interesting. I like it, anyone ever use it on a S2000?
Old Feb 11, 2010 | 05:35 PM
dsddcd's Avatar
I and many others went down this road many a time (SEARCH) so I will give you the very short version to get you moving forward.
The AEM has a much better options for knock detection, which are actually tunable, than any of the units you selected. If you want a light just enable an output in the EMS which will flash an LED or Buzzer which will denote knock.
If you want something really sophisticated look up closed loop knock detection which can be found in the newest Motec units. Tony at T1R was one of the first to work with one and can give you details. Otherwise you need a factory ECU from something like a Subaru or Dodge.
Oh and in your search you will probably find Ion Sensing Sprak Plugs, and Pressure sensors in each cylinder but you won't find any luck with this technology. Most aftermarket systems are about 10 years behind the OEM's.
Old Feb 11, 2010 | 05:51 PM
RacerXI's Avatar
They were all the rage back when hondata was the only option for engine management on b-series. The jackson blower guys loved it.
Old Sep 19, 2010 | 07:35 AM
John at J&S's Avatar
Check my home page for link to the new interceptor version.
Comparison to AEM knock detection:
http://jandssafeguard.com/Giles/AEM%...%20log%20.html
CLEANs2000
Sep 21, 2010 06:21 AM
dales2000
Jun 21, 2010 09:20 AM
chopper-world
Apr 17, 2008 04:46 AM
1SickS2
Sep 10, 2006 08:48 AM
fperra
Jun 4, 2003 07:44 PM
