For all the Turbonetics Godzilla BOV owners...
Ok...I just installed my Godzilla BOV on my Comptech supercharger. It took a long time (the directions provided suck) and I think I have all the connections right.
Anyways, the BOV goes off every shift from 2nd til 6th (if I shift above 4k RPM). Sounds okay...not like turbo systems (yes, I've done extensive searching on S2KI and I understand that BOV will not sound as cool on superchargers).
The only thing is, the BOV constantly releases (more like whistles) while decelerating. It's really annoying, especially on the freeway because when I let go of the accelerator, the whistling is really loud. In any gear, the whistling doesn't stop until the RPM's decrease below 4k RPM. It sucks because I like to downshift to engine brake; now I have to pop it in neutral for the loud whistling to go away.
I've heard of other members complaining because their BOV's won't go off...but I can't get mine to shut up (although I like the brief WHOOSH on the upshifts). I've tried tightening and loosening the bolt on top of the BOV, but it doesn't do anything.
Help anyone???
Help anyone???
Originally Posted by S2000RAT,Apr 12 2005, 06:08 AM
Mine does not "whistle" it is a loud blowing sound when I am not on the gas.
Do you have the vac. line in the top?
RAT
RAT
Anyone?
Not sure on the Godzilla, but I know on the Greddy type-s I had it would get the same little whistle at low boost to vacuum conditions. The reason it whisles is that there isn't a lot of pressure and only opens the BOV a little bit...kinda like opening your mouth wide and blowing (easy guys) compared to opening your mouth slightly and blowing (whistling). The way to fix it so it doesn't whistle is to tighten the spring on the top so it takes more boost pressure to open the valve..the problem with that is you might get compressor surge (not sure if that's a problem with SC..I know it is with turbos). Hope this helps.
Originally Posted by 600rr_rocket,Apr 12 2005, 11:47 AM
Yup, I have the vaccuum line connecting from the BOV to the engine intake manifold. There are actually two holes in the BOV; I tried both and only one causes the BOV to release. I have no idea what the other hole is for.
Anyone?
Anyone?
