Angled oil filter adapter, need some help.
I´m looking for a 45 or 90 degr adapter, anyone using this? Would be a perfect way to clean up the engine bay and get rid of the oil lines, would clear the manifold without a problem.
Here´s a pic to explain:
Sorry for all the questions but have a feeling that it might help other members as well.
That´s why I need you guys, JEGS and Summit should have some but my English suck. Sometimes the adapter itself work if you modify/change the thread size.
Not 100% here but I think we have M20x1.5, found a nice one yesterday using 3/4", will buy that one (used for 20 bucks) and see if I can make it work.
Like the middle or last one.
Maybe FBM can machine a bunch?
Bought one today, will start working monday, will keep you updated. Will go Honda threads since I want to keep it simple and according to many the S2K filter´s the only good option.
Thanks guys and Happy New Year! (Go Cerrone and Alex)
If I did this right you should be able to tap out the bolt that holds the oil filter adapter to the block from 3/4" thread to M20 X 1.5 thread.
0.75 inch = 19.05 millimeter
And then you could run a big filter like this
http://www.wixfilters.com/filterlook...asp?Part=51515
and if that filter isn't big enough they make a 2 Qt. filter for 3/4 X 16 thread.
I run a very large filter(over twice as big as the stock S2000 filter) on my "S" and this would work real good on my car.
Thank's for finding that adapter,
ROD
ROD
