Another Internal Wastegate question
Old Aug 3, 2008 | 07:45 AM
Revenge's Avatar
yes it has an internal WG cause I used the greddy manifold, I will have to ask JEimports how much for the DP, I will try and take pics once I get my car back at the end of the week so you can get an idea.
Old Aug 3, 2008 | 08:02 AM
KnowledgeIsPower's Avatar
awesome thanks
Old Aug 3, 2008 | 08:10 AM
TelosHedge's Avatar
i would imagine with a 3076 you'd run out of fuel with 550s before you had to start worrying about turbo efficiency. however if i had to guess i'd say something like 15-16psi. i'm sure some of the older inline pro users can chime in here.
Old Aug 3, 2008 | 10:03 AM
Spec_Ops2087's Avatar
Yeah for our motor, 16psi or so is the sweet spot for the GT3076.
Old Aug 3, 2008 | 10:08 AM
revenge how much was the turbo? and where did you get it from? PM if u want.
thanks
Old Aug 3, 2008 | 10:32 AM
JoeyBalls's Avatar
also no Boost creep issues?
Old Aug 3, 2008 | 10:37 AM
JoeyBalls's Avatar
isnt the Greddy kit using 750"s for the injectors?
Old Aug 3, 2008 | 10:50 AM
Revenge's Avatar
My greddy kit came with 550's, from what JEimports said it held right at 8psi with no spikes (it has been warm though) and now it has a much larger DP 3". I think this turbo kit should be much more upgradable I did a bunch of searches and people make 400HP+ with a gt30r. I think I am ok with 303 for a bit, then I do stage II a 3mm HG and turn up the boost to 16psi if thats that's sweet spot.
Old Aug 4, 2008 | 07:33 AM
devs2k's Avatar
[QUOTE=Revenge,Aug 3 2008, 02:50 PM] My greddy kit came with 550's, from what JEimports said it held right at 8psi with no spikes (it has been warm though) and now it has a much larger DP 3".
Old Aug 4, 2008 | 08:57 AM
Revenge's Avatar
Originally Posted by devs2k,Aug 4 2008, 07:33 AM
when do you hit full boost with the GT30? I know I hit 7 psi at 3500 rpms with the greddy.. it might be slightly higher for a F20
I'll pick the car up Friday or Saturday, I am too busy with work this week to go get it. I'll let you know when I get the chart and drive it a bit.
