any cop issues with open wastegate noise?
No sense in being paranoid, just don't got WOT when you're unsure if the road is clear of cops. They aren't supposed to pull you over for what they hear, only what they see.
Then again, you live in NY. They send dudes to jail for shooting themselves so I dunno.
Originally Posted by josserman,Sep 24 2009, 04:20 PM
Have any of you had an issue with cops stopping you because of the loud noise from the wastegate opening? Obviously if youre wategate is open all the way you're probably going really fast and the cop would stop you for that, but I'm more thinking of a situation where a cop is down the road and doesnt see you, but hears you and then when they drive by your car and see it looks like it may be the culprit (ie gauges, jdm looks, ect) they pull you over? I'm just super paranoid and want to get a feel for others experience.
thanks!
thanks!
<------------huge giants fan here
Originally Posted by rob!,Sep 24 2009, 04:28 PM
dude you are really blowing this whole wastegate thing out of proportion lol. The wastegate isnt loud unless it is open. Its not open unless you are WOT. If a cop sees a 400+whp car flying by WOT then you have more issues to worry about then a wastegate sound.
Its a high revving 4 cyl. turbo car. Its going to be loud to some extent. I have not been pulled over because of how loud my car is. If you are speeding then you are speeding and consider yourself lucky if they let you off the hook with a loud exhaust violation.
You just got the car turbo'd. ENJOY all the money you spent its actually a lot of fun lol
Originally Posted by DeadZero,Sep 25 2009, 01:40 PM
it must be loud huh? do a custom setup were the waste gate directs its flow into the down-pipe.
from what i know no matter what spring is in the wastegate it doesnt open until you hit the desired boost.
So say you have a 4lb spring and boost is set to 12psi. wastegate will not open until 12psi. now, say you put in a 10lb spring and boost is set to 12psi. wastegate still is going to open at the same time you reach 12psi.
hmm Jeff D and Jeff E thought this route may help reduce the wastegate noise so I'll try and find out how that all works.
I feel like I'm getting a bit more used to the noise now though and taking your advise and enjoying the car....check out my porsche kill from this am in the NYM section!
