Anybody running RC 1000cc?
Old Oct 24, 2010 | 11:03 AM
  #21
godmachine's Avatar
Because Rc injectors suck and resistor box will fail ?
Old Oct 24, 2010 | 11:46 AM
  #22
S2BOOSTED's Avatar
im going to order them tommrow : )
Old Oct 24, 2010 | 11:48 AM
  #23
Suzuka_Joe's Avatar
Umm because your car will run 100x better with the id1000's.
I'm done though. It's not my car so I don't really care
Old Oct 24, 2010 | 12:04 PM
  #24
Sideways's Avatar
Check out injector drivers as well as resistor boxes.
Depending on where you mount it you will probably splice 4 wires in your harness. I suggest under the dash to avoid the weather.
Solder the connections and heat shrink to insulate well.
I got one of these: https://www.s2ki.com/forums/index.php?showt...&#entry14334783
Old Oct 26, 2010 | 03:05 PM
  #25
NaturalAspirations's Avatar
What city are you located in? I can install the resistor box if you need? RC injectors run perfect just make sure you have a resistor box of OE quality and make sure the latency is adjusted corectly in your efi calibration. No need for ID unless you want a small compact 2000 cc injector. RC FTW!
illist2k
May 10, 2017 08:44 AM
albe
Oct 26, 2009 11:23 AM
s2mmkay
May 21, 2009 08:34 AM
syellow
Nov 29, 2007 09:14 AM
Venomous S
Jul 31, 2007 10:17 PM
