anybody using anti engine stall on emu?
Old Jun 26, 2010 | 01:11 PM
realblag's Avatar
Thumbs up anybody using anti engine stall on emu?
I installed a used greddy AP1 bolt-on kit. When I start the engine (cold), it starts, runs until the fresh air system turns on, then dies. I restart and it runs fine( with fresh air system running) but if i give it some throttle then let off, it will fight not to stall. After the engine begins to warm up, the idle speed gets lower as it should but it is more difficult for the engine to stay running. At normal operating temps, when I let off the throttle, it will surely die unless I pat the pedal a few times and ease it down to idle speed. The map on the E Mamage Ultimate is the unaltered base map and none of the other settings have been changed.
Will setting up the anti engine stall on the EMU correct this? Has anyone else had an issue like this? Please help
Old Jun 27, 2010 | 07:17 PM
realblag's Avatar
nevermind...I got a copy of the E-Manage software, updated the EMU, and reloaded the map. Also I let the car warm up till the fan cut on without touching the pedal. It works great now.
Old Jun 27, 2010 | 08:12 PM
jb34304's Avatar
Glad to hear you got it running. I hope you get it tuned by a pro soon tho.
Old Jun 27, 2010 | 08:29 PM
StocS2k's Avatar
Sounds Good ...Always Trial and Error
ManOnFire75
Oct 28, 2013 05:09 PM
yourboysoap
Jun 24, 2011 06:52 AM
macr88
Engine
Jan 21, 2010 11:22 AM
lotus7racer
Apr 11, 2009 01:41 PM
Wesmaster
Dec 1, 2003 08:42 AM
