Anyone running Emanage Ultimate with turbo?
Old Sep 19, 2006 | 01:59 PM
afwfjustin's Avatar
Default Anyone running Emanage Ultimate with turbo?
I know this is a relatively new product and a lot of people say not to use it due to it being confused with the blue and that not many people are rocking it yet, but the same went for the EMS when that was new as well.
The Ultimate allows you to control injectors and timing, and I'm curious as to whether or not anyone is running this with a relatively low turbo boost level (6-8 lbs). The added benefit of being able to keep your stock ECU and OBDII port would be a plus as well.
Any input?
Old Sep 20, 2006 | 08:55 AM
Chitah831's Avatar
the only input i have is that I'm running the blue version with my turbo. Also controls the injectors and timing. Not ideal, but at 7psi it works well for me.
Old Sep 20, 2006 | 09:26 AM
JDM S2000's Avatar
Banned
Id like to know also, I do not plan on going over 8psi and i dont not want to spend more on the aem unit then i did on my turbo kit so Im looking for alternatives
Old Sep 20, 2006 | 04:49 PM
afwfjustin's Avatar
^I hear that. I'm hoping twiztid will chime in since he's a big ultimate tuner. I know the blue only controls up to 550cc injectors but I want to do around 8 or 9 pounds.
Maybe I'll call around and see if anyone can tune the thing.
Old Sep 20, 2006 | 05:01 PM
Chitah831's Avatar
I'm using 600cc injectors.
Old Sep 20, 2006 | 05:08 PM
afwfjustin's Avatar
That's about as high as the Blue can control right?
What is your power output? Got a dyno graph?
Old Sep 20, 2006 | 05:32 PM
Chitah831's Avatar
I'm not sure what the highest is, but the car drives fine and doesn't seem to be on the "edge". It did take me a long time to get some part throttle issues worked out. But it drives just like stock now.
I haven't gotten on the dyno YET, but I plan to sometime soon.
Old Sep 21, 2006 | 04:26 PM
ScottyBallistic's Avatar
You rang ??
Blue can add fuel via injector and subtract via MAP voltage. While it works to a degree .
Ultimate can add and subtract via the injector . Much more stable and precise solution .
The Ultimate can also control timing more accurately.
Heres what some dont get , if it can run on a blue it can run on the Ultimate . I have even used the Ultimate in cars that are not even supported ( 99 Maxima- took some tweaking and a little solder work , and right now in a 06 Lotus Exige -new computer for 06 not made buy Toyota so the 2zz settings dont work)
Not going to get into to much detail as I am not in the mood to argue.
Those that have PM'd me do have my number and are welcome to call
lewiS2K
Nov 7, 2009 10:27 AM
combats2000
May 24, 2009 05:09 PM
Kirpich
Feb 28, 2009 03:26 PM
Aznpridedan20
Oct 22, 2004 02:56 PM
Wesmaster
Nov 20, 2003 06:53 PM
