Anyone running an intercooler fan?
Old Apr 20, 2009 | 05:46 PM
  #21
Soul Coughing's Avatar
Originally Posted by Spec_Ops2087,Apr 19 2009, 11:44 PM
I can guarantee everyone with an intercooler experiences the same thing but I doubt many people have a water temp gauge like I do to actually "see" the fans turn on while highway driving.
are you sure you aren't just seeing the thermostat opening up? I also see similar cyclical drops in temperatures, even when my radiator fans have been disconnected (troubleshooting a headgasket issue)
OT:
I wouldn't worry about the fan. What ever drop in IAT will be small enough to be lost in the 'noise' of regular driving. That isn't even including the added complexity of either turning on the fan everytime you are in stop and go traffic or the added backpressure the air will see when you are driving at highway speeds.
Old Apr 20, 2009 | 08:06 PM
  #22
WashabiS2K's Avatar
I do and I can definitely see the difference that my FAL Fans produce when they are switched on. My EMS is tuned for the fans to come on at 210
Old Apr 20, 2009 | 09:06 PM
  #23
spdracerut's Avatar
Originally Posted by Spec_Ops2087,Apr 20 2009, 05:21 PM
We arn't driving Evos or or nissans -- we are driving s2000s. Unless you have a water temp gauge on your turbo'd s2000, then you can't say whether it will happen or not...
Yes I have a large intercooler, but I had a much smaller one originally and the same effect happened.
Your motorcycle? Come on dude. The engine is smaller, there is less coolant overall, better overall air flow to the radiator, etc. I have never once seen my coolant temps DROP while driving on the highway even during the winter. They stabilize if anything, or climb to ~205F fans kick on drop to 190 and the cycle repeats over and over.
Yes I have a radiator shroud
I was actually refering to the undertray.
The point I'm trying to make is that a proper cooling system does not require a fan when moving.
Yes, the S2000 has a pretty small frontal opening area. Probably why the car comes with an oil cooler that transfers heat to the coolant instead of having a heat exchanger with the air. Adding a front mount certainly doesn't help.
Personally, this is why I think only a tube&fin intercooler should be used.
I guess your situation just shows how a IC can really restrict airflow to the radiator. I would re-evalute your setup; you may need a vented hood to help draw air out of the engine bay and therefore through your radiator.
Old Apr 20, 2009 | 10:44 PM
  #24
Spec_Ops2087's Avatar
OT:
I would assume its the fans because at idle I hear them kick on at ~205F and turn off once the water hits ~190F and that's exactly what sometimes happens on the highway on hot days
Old Apr 20, 2009 | 10:47 PM
  #25
Ah well I still have the undertray in tact
I'm not denying that, but I am saying that with an intercooler, the fans will turn on during hot days to drop coolant temps on the highway
Its not really an oil cooler, more like an oil warmer if anything
I have a vented hood so only thing to do is to upgrade the radiator and even then the fans do their job and every other turbo s2ks so I don't really feel a need for upgrade...maybe one day
Old Apr 21, 2009 | 08:35 AM
  #26
Did you mount the temp sensor on the upper radiator tube?
I'll make a bet that if you disconnect the fan's and drive at highway speeds, you'll see similar cyclical temperature fluctuations. I know i did!
Old Apr 21, 2009 | 08:58 AM
  #27
Its tapped into the coolant line that runs to the throttle body (underneath it) from the engine.
I thought the thermo started to open at like 160F and was fully opened by 190F ish? Have to check the helms manual to see.... I like to be proven wrong if I am indeed mistaken
Charper732
Aug 13, 2017 07:54 AM
josserman
Feb 6, 2014 08:31 PM
dan_uk
Feb 5, 2014 04:50 PM
JoeyBalls
Aug 19, 2008 12:51 PM
afwfjustin
Oct 30, 2007 04:26 PM
