Anyone running a Li-ion battery
Old Sep 8, 2016 | 07:22 AM
Sideways's Avatar
Default Anyone running a Li-ion battery
I am curious if any of you are running a Braille battery or the equivalent. I am tired of the AEM not starting with 12.4 volts or so.
How has it worked out for you? Enough reserve capacity?
Thanks in advance.
Old Sep 8, 2016 | 08:21 AM
MemphiS2k's Avatar
I wouldn't use one in a car I needed to depend on/always keep on a battery tender.
Old Sep 8, 2016 | 03:12 PM
WilloW's Avatar
I ran a Braille on my old S14 for over a year without any issues and it was still working perfectly until the new owner wrecked the car. I would definitely buy another one in the near future for the S.
Old Sep 13, 2016 | 06:42 AM
timg's Avatar
I have been using the Shorai LFX36L3-BS12 lithium battery. The only downside is that you need to disconnect it when the car sits for more than two weeks without running. Otherwise, it has been flawless.
Tim
Old Sep 16, 2016 | 03:24 AM
Redline S2K's Avatar
I was using a ballistic then switched to a Scorpion LiPho4 battery. Here is the DIY I did
https://www.s2ki.com/s2000/topic/105...elocation-diy/
If you do a lithium battery, highly recommend a lithium battery trickle charger.
Old Sep 17, 2016 | 07:59 AM
boostedf22c's Avatar
We've used several lightweight lithium batteries throughout the years and of those batteries these guys have the best one.
http://www.golithium.com/
Old Sep 17, 2016 | 12:15 PM
cujet's Avatar
I've used the Lithium Iron batteries (that's the type typically used for vehicles) in everything from Experimental Aircraft, Motorcycles and Regular cars. They are very lightweight and have incredible cranking power, as long as they are not cold.
I've recently been purchasing lithium motorcycle batteries from "Batteries and Bulbs" a franchise chain, that sells the K2-Energy brand (locally at a good discount) (also avial on Amazon)
http://www.k2battery.com/
The K2 Energy batteries have very robust terminals. Something lacking on many other brands.
Just know that they won't power your headlights or domelights for as long as a stock battery. They crank better, but don't have the stored energy to run a load for a long time.
If you have an alarm that has quiescent current (draws current when the car is off) it will deplete a lighweight lithium battery more rapidly than the stock battery.
jonybravo78
May 8, 2012 10:19 AM
jpembry
Dec 30, 2011 06:33 AM
Ks320
Apr 25, 2009 04:49 AM
fadiss2k
Jul 11, 2007 08:51 AM
LUV2REV
Oct 19, 2004 06:05 AM
