Anyone safely running 7lb pulley without..
I have Comptech SC w/o Aftercooler / Comptech Exhaust. Im running the stock pulley, Im not interested in huge numbers but 300whp would be ideal- Im guessing to be around 280-290whp right now and I figure a 7lb pulley would put me where I want- Ive heard of people running 7psi on the Comptech ESM and Ive also heard the stock injectors should be ok up to around 330whp- If I get the pulley and take it to a dyno, what tunning can they do to accomodate the extra boost?
Ive been told the Tech2 7lb pulley is the way to go- I havnt researched where to buy as of yet- Ive been getting mixed responses to going this route and am just trying to gather information at this point- Are you running 7psi on the stock kit right now?
try http://www.aspracing.com.
I've heard of fitment issues in the past w/ Tech 2, not sure whether it was w/ vortech pulleys or comptech but personally it's not my preference to go w/ tech2
Originally Posted by Venomous S,Mar 3 2006, 05:44 PM
i beg to differ
I believe with the Comptech, you'll need to remove the blower. Just unbolt the whole mounting bracket. If you don't have a impact wrench, loosen the pulley bolt while the belt still has tension.
Also wondering about this, Im in the same place as DEEZ comptech kit with no A/C and looking to upgrade to a 7lb pulley sometime in the future. Has anyone been running a 7lb pulley with a non aftercooled kit for a while. I wonder if this holds up fine with long time use on it.
