Anyone try e85 with a supercharger yet?
Old Sep 14, 2009 | 08:42 PM
ILoveMYHonda1984's Avatar
Default Anyone try e85 with a supercharger yet?
Ok so I live in the Midwest and e85 is readily available. I have a SOS supercharger with 12 psi pulley. I have upgraded the pump and am running a boost a pump that increases voltage with boost.
Question is, has anyone done e85 on their s2k with a supercharger? Ill be runng 825cc injectors.
Any help suggestion are appreciated.
My tuner is big on mustangs and camaros with returnless fuel systems and they love e85!
www.houseofboost.com
Update- found this post and added my dyno. This is old news now but just thought id post it
Old Sep 14, 2009 | 08:44 PM
s.hasan546's Avatar
boost a pump wont help u. upgraded pump wont either. your an 06+ u hv to convert to return line fuel system to be able to run e85 and actually make some power
Old Sep 14, 2009 | 08:53 PM
soulicious's Avatar
ILoveMYHonda1984: What size pulley are you using for 12psi on your AP2?
Old Sep 15, 2009 | 05:13 AM
Ill have to measur it and get back to you. SOS said its the same size they used on the d sport challenge car.
What is it about the return less system that keeps it from flowing? These guys @ house of boost have a lot of experience with returnless cars and think they can work it. I'm excited to see some fresh eyes give it a go round and not just repeat what they've read on here. Ice talked to the techs @ SOS, Kraftwerks and king Motorsports and nobody really has much experience with it. I'm excited to try it. I can always go to a return If this doesn't work. 400hp is my goal and I won't boost more than 12psi. That's already on the extreme for a stock block.
Ill post more tonight when I know more.
Old Sep 15, 2009 | 05:53 AM
KewlWhip's Avatar
Only 400WHP, then you won't need e85. 93 pump gas will be just fine. Hell, Jeremy put down 471 on 91 pump gas on a stock block with a returnless fuel system.
12psi on a stock block is not extreme. I'm doing e85 on a stock block and shooting for 600WHP on my '07. We'll be north of 12psi for sure.
I don't know if they still say it but SOS and Hondata used to say 400WHP was the limit of the returnless fuel system. Well, it's not. You can get 490- 510WHP on 93 octane with the returnless fuel system.
-Chris
BTW - the returnless fuel system will not support my needs.
Old Sep 15, 2009 | 08:59 AM
camuman's Avatar
pm tony1 at t1 racing, he tuned/ i thin built berlinas2k car that made nice power. but i think they used 1000cc injectors.
Old Sep 15, 2009 | 06:29 PM
well didnt make the tune today. Got a late start. Added the 850cc injectors that are actually stock from a Shelby GT500, haha. I have Ford parts on my car. Then I put on the SOS 3 bar map and wired up the boost a pump. Did a street tune just getting it richened up. My tuner will take his turn in the morning. We are tuning on 92. Should be good. Im halfways wanting more boost already. I wonder what the max safe boost is on this motor with a supercharger? Im down for more, as long as its not going to kill it too quickly.
Ill post more tomarrow
Old Sep 15, 2009 | 09:41 PM
PsykotiK's Avatar
remember that u dont want to exceed the capabilities of the SC.. you can only make so much power
Old Sep 18, 2009 | 06:15 PM
made 386hp and 262tq at 7750rpm. Im not sure why my tuner didnt take it a little higher. I made 10psi at the manifold. I have a 3in pulley, the smallest one offered by SOS for the 1220 Paxton, going on Monday. I will take my car over to the dyno Monday afternoon and have them touch up the tune and dyno it again. This time I will go to 8200-8400 or so, just to show what it is capable of. I typically shift at 7800 or 8000. From the way the dyno graph appears, I would have made 400 wheel right at 8000rpm this time. Another 1 psi pf boost and cooler temps next week should show good numbers.
No e 85 at this point. Fuel pump wil need to be upgraded again to do that.
The car drives awesome. Juts amazing. 100mph comes so quickly now. I couldnt imagine what this car with 500whp would be like. Ill post more monday evening.
Old Sep 18, 2009 | 07:03 PM
smirfs2k05's Avatar
hows driveability with the kpro ?
