Ap1 ctsc boost problem
Old Oct 20, 2011 | 08:29 AM
jordannn93's Avatar
Default Ap1 ctsc boost problem
I have a ctsc aftercooled setup with a 4.25 pulley. It would always boost at 7psi but up until yesterday the gauge wouldn't go over 5psi. What is wrong ? Can anyone help me
Problem fixed - boost gauge hose had a small hole or something in it . Replaced with new line
Old Oct 20, 2011 | 09:03 AM
s2konroids's Avatar
Most likely belt slip for sure, it will only slip at high revs typically around 7500rpm and onwards.
Old Oct 20, 2011 | 09:14 AM
jordannn93's Avatar
How do I know for sure? And how can I fix this? The belt is in very good shape
Old Oct 20, 2011 | 01:04 PM
s2konroids's Avatar
If you have any logging software on an ECU you will tell, or if you closely watch your revs and boost gauge and see where it drops, probably around 7.5-8k - maybe better getting someone else to look at the revs and boost.
My belt was okay and new'ish a while back but became loose -so it does happen, they do have to be tight.
Old Oct 20, 2011 | 01:52 PM
jordannn93's Avatar
Like how tight? Mine Seems pretty tight . My boost won't build higher than 4 doesn't even drop . Do you think it's my gauge ? Vac is at 18 during idle
Old Oct 21, 2011 | 08:36 PM
jordannn93's Avatar
Borrowed a friends boost gauge , it fixed the problem.
I had a auto meter sport comp.
SeanSerino
Jul 9, 2010 05:43 PM
jdmdohcpower
May 29, 2009 02:09 PM
crav3s2k
Jan 3, 2009 10:36 AM
SilverKnight
May 16, 2006 07:39 PM
Salaska
Oct 13, 2004 06:41 PM
