Ap1 Vortech v2 conversion to 2006 DBW
a buddy of mine has Vortech v2 self-lubricated supercharger on his MY00 and I want to convert it to MY06.
From what I've read, I will need new injectors and flashpro. I also want to convert the Spearco radiator from his car to MY06. Where can I find the harness for that or do I have to make my own? Do I need to modify the crank pulley (thought I read this somewhere.)Tap the oil pan? Are there any other modifications that I will need to do make this work??
Why do you need a harness for the sparco?
The kit should come with a modified crank pulley. If not, then take your oem one along with the attachment and have it tapped at a machine shop.
Vortech says to tap the oil Pan for the drain line, but I've seen a -8 to 14mm x 1.5 fitting be used in place of the drain plug with no problem.
I would grab vortech
tom153
Jun 21, 2017 06:39 PM
watch0bak
Forced Induction For Sale
Oct 22, 2012 08:25 PM
