Apexi turbo timer on Supercharged S?
Old Apr 11, 2005 | 11:15 AM
nsxinsac's Avatar
Default Apexi turbo timer on Supercharged S?
Is there any benefit to have one. I know it is important to cool your turbo and engine with a turbo application but how about with a supercharger? It was nice to have when I had one on my fd3s rx7. Anyone here use one? Here is a link where someone is using one.
Pic of SC S2000 with Turbo Timer
Old Apr 11, 2005 | 01:27 PM
kane.s2k's Avatar
useless
Old Apr 11, 2005 | 02:45 PM
fperra's Avatar
That's why it's called a turbo timer.
Old Apr 11, 2005 | 03:30 PM
Doss's Avatar
Waste of gas
Old Apr 11, 2005 | 05:26 PM
nsxinsac's Avatar
I thought so. I know superchargers run alot cooler than turbos but just want to see if anyone is running one and why. Thanks for the input.
Old Apr 11, 2005 | 05:39 PM
Slows2k's Avatar
Since the SC isn't spinning with the engine off, there is no reason to use one.
Old Apr 11, 2005 | 07:56 PM
Doss's Avatar
what? The turbo doesn't spin with the engine off either. The turbo just has hot exhaust air running through it and the S/C does not. If the oil isn't allowed to run through the turbo to cool it down a little it will damage the turbo.
The S/C doesn't get nearly as hot you can still put your hand on it after hard runs, whereas on a turbo you can't even put your hand near it without feeling a lot of heat.
Old Apr 11, 2005 | 08:01 PM
Slows2k's Avatar
Sorry dude, The wheels in the turbine are still spinning after you shut the engine off. The turbo is not mechanically linked to the crankshaft like a SC. A turbine wheel spinning at 20,000+ rpm doesn't stop moving when you shut the motor off, it take a while for it to slow down. Turbo timers are used to allow a cool down period for the turbine, and to prevent from cooking the oil in the turbo at shutdown.
Old Apr 11, 2005 | 08:10 PM
kane.s2k's Avatar
exhaust gases >>>>> engine oil temp
the turbo center cartridge is insanely hot well after the turbo has finished spinning.
Old Apr 12, 2005 | 07:50 AM
Doss's Avatar
[QUOTE=Slows2k,Apr 11 2005, 08:01 PM] Sorry dude, The wheels in the turbine are still spinning after you shut the engine off. The turbo is not mechanically linked to the crankshaft like a SC.
